Patton (HASF1016UC) Stand (Pedestal) Fan Logo
A
Anonymous Posted on Jun 09, 2014
How do I fix a pull chain that broke off inside the motor
My patton fan pull chain either pulled out or broke off. It is a 2 speed fan (high off low) and it broke in the off position?
4 Related Answers
Anonymous
  • 51 Answers
  • Posted on Jan 01, 2009
SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Anonymous
  • 8 Answers
  • Posted on Sep 07, 2010
SOURCE: where do i find a replacement motor for my patton
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Anonymous
  • 927 Answers
  • Posted on Aug 17, 2011
SOURCE: NEED REPLACEMENT MOTOR FOR PATTON
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Anonymous
  • Posted on Aug 24, 2012
SOURCE: Need new motor for Patton High Velocity Air
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Harbor breeze fan remote
If the fan has a pull chain then push the Hi button and then pull the chain until it's on high. Then don't pull the chain! If that's not your problem then check the capacitor in the fan.
Jul 15, 2013 • Dryers
Hello. we have just purchased a new Hunter ceiling fan model 20593 with the remote. we installed it and got it working but, it will not go fast at all. we looked at the instruction manual and found that...
It's been awhile so you've probably quit by now, but if yo haven't , try this: Get up into the light bowl area nad look for the pull chain on the side of the housing. Pull it 2 times and it should put the motor into high speed. Click the #3 on the remote and see if it goes to high speed. If not, pull the chain and try again. Keep doing this until the motor gets into high speed. It should only take a few times at most.
Low and medium fan speed no longer works on our Hampton Bay fan when you pull the chain. The high speed works. Can this be fixed with a repair part?
the speed is controlled by a capacitor bank ... high speed uses no capacitors, low speed uses a small capacitor in series with the motor and medium speed uses a larger capacitor ... the pull chain switch selects which capacitor is used ... so if the capacitors go bad or if the switch fails to select them then you will not have low and medium speed ... so you could have a bad speed capacitor block or a bad switch or wiring that has come loose inside the fan (that connects the capacitors) .. all are replaceable .. i would first remove the covers from the fan and check all wire connections .. check the switch to see if it operates smoothly .. then suspect the capacitor block .. if you were an electrician then you could bypass the switch to test its function but if you are not then make sure power is off while working on the fan .. you should be able to get a new capacitor block from the manufacturer .. most are similar if they will phisically fit in the fan housing and have the same connectors ..
Need to fix the pull chain on a model P3086
It uses a standard pull switch available at most hardware stores, just make sure you get one with the same No. of speeds and transfer one wire at a time.
Jun 30, 2010 • Dryers
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
6helpful
2answers
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
10helpful
2answers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
1helpful
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Our handyman installed our Hunter Douglas Westside fan yesterday, and there is still a strong electrical burn smell everytime it's on. Should I be concerned? Thank you!
If you are controlling the fan speed with a wall type dimmer switch, the mechanical pull chain switch must be in the high speed position ONLY. If the pull chain switch is in the med or low position and you are using a dimmer type wall switch to control the speed you are burning the motor up. If this does not apply to your situation then it is possible that the fan is defective or maybe some packing material inadvertantly got inside the fan
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Top Patton Dryers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Patton Dryer Expert? Answer questions, earn points and help others
