Found an old powerseeker 114 eq, not sure if the dec setting circle is still at factory settings.
SOURCE: Can't set up
You can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
SOURCE: Recall?
I think Sony will cover this for you regardless of when you bought it. Call SONY customer service and I think they will make this repair at no chrarge
SOURCE: setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
SOURCE: Starview codes Dec 18th
I found a fix for Chorus Cork using my Starview The Box Super 3 !
(dated Dec 19,2008)
1. Upgrade your firmware using the GTROM v8.02e.
2. Change the codes using:
Chorus
00 - CE 19 2E 87 80 61 74 90
01- DD FA D9 F3 CE 05 FA 79
NTL
B0 B8 4F 04 E6 5F 87 80
A3 EB EC 07 D6 49 D2 EB
(How do you do this? Using your remote, click Menu, press 1570, press NagraVision, then change the codes using your remote as your keyboard with the buttons=characters/#s on the screen as guide). Then Exit.
3. Goto menu, select Insatallation, Select CHORUS, then select Automatic Scan. Once finish exit and check if channels are ok.
If the channels are still showing nothing..
3. Press Menu again. Choose factory settings, enter 0000 as code. then press OK to delete/reset.
4. when your back to the Menu, press 1570 then set EMU to On again. Exit.
That should work now. :) Happy Christmas everyone!!
SOURCE: Dec fix kit for meade lx50
Dr. Clay Sherrod performs telescope upgrades, he can probably help.
Try the following links:
http://www.arksky.org/supercharge.htm
Here is one person's review:
http://www.cloudynights.com/item.php?item_id=1361
