Passenger side a/c blowing hot air, driver side is cold.
There's a rod assembly that opens and closes the vents in the car
for the automatic climate control. It's supposed to open all vents to
the AC feed when in AC mode. BUT, if it slips loose, the default
status is to feed heat through (you can open a window in the summer,
but you don't want AC blowing in your face and on your windshield in
the winter). In my case, the driver's side was working right, pumping
cold air, but the passenger side was actually dumping hot air into the
car. Friend who fixed it for me told me he just had to
drop the glove box etc. on the passenger side to get to the rod and
slipped it back into place. I'm not agile enough, but if you are, you
can probably crawl around under there and figure it out - or get a
friendly mechanically inclined young friend to do it for you. Probably
in the mechanic's manual for the Caddy (I don't have one).
Think this will fix it for you - did for me.
Good Afternoon Friend, I understand that your Frigidaire air conditioner blows when it drops to 72 degrees and you want to know why. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you leave your model number for me. You can typically find this number located on around the edges of your air conditioner or behind the front grille. Looking forward to hearing from you. -WP-
