I posted this response to s-one else's similar question ; the details sound slightly different, but you may find this close enough to be of some use. (btw, I had stumbled along just about the same as you have described, for some time, previously.)
I hope this helps.
... I'm not familliar with your particular clock, but, I'm assuming you may have a;
BATTery operated, wall-hanging, 'self-syncronizing' clock with 'hands' on it.
These are often marketed as 'Atomic' Clocks that 'keep perfect time - all the time'.
Generally these work by 'accuratizing' the Minute-hand as it approaches the 'top-of-the-hour' position (e.g. the 60th. or the zero- minute marker at '12'. They often achieve this by either 'double-Clocking' or 'half-clocking' (doublespeed or halfspeeding) the electric pulse that makes the 'SECONDs' hand advance to it's next mark. These 'SynCHRONO-ize' to a low-frequency Amplitude-Modulated (AM) radio-wave signal, (perhaps near 430Khz?) emminating from a source near "The Atomic Clock" out in Colorado (I believe).
One that I used to have hanging had recommended something like the following:
-manually adjust the time (via the small grey wheel near the BATTery, but set it about 7 to 12 minutes 'early' or before the actual correct time, (preferably at about 10 min. before an Hour).
-then remove the one " double A" . . .
... battery (for about 30sec.) and reinstall battery.
-then hang it up, and watch for the second-hand to do its 'Double-clocking' (for part of it's revolutions ) as the Minute-hand apprpaches th '12'. {note; it may take ~2 or 3 hour-cycles for the minute-hand 'to catch-up on all it's "Lost" minutes}.
(then, hopefully, your model will stay 'synchonized' there, for that 'Hour's' setting, and accept It (DST Hour value) with accuratizing Minutes. (and not go crazey over the next few days trying to get back to "Real TIME"). /mm
/mm
butifallelsefailsreadthedirectionsand,
basicinstructions'boutlife(on)earth.
Posted on Apr 26, 2016
Posted on Apr 27, 2016
I do not have the same clock, but I assume the atomic receiver is the same. I found my clock went berserk if it was anywhere near anything else electronic. I had it on a dresser that was sharing space with my wireless printer. Once I relocated the printer, the clock went back to normal. You may have a different issue, but maybe check that nothing is around that would cause interference.
SOURCE: LACROSSE WT-3161 wall clock. Can't set to Pacific Daylight Savings. Keeps Resetting back to PST
See http://www.lacrossetechnology.com/3143a/manual.pdf Press the unmarked button for 1 second. That turns DST on and off.
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
SOURCE: I set my clock to
The best solution to all these Zenith clock radio problems is to just throw the damn thing out and go to WalMart and buy the cheapest " anything but a Zenith" that they have.
SOURCE: MODEL:WT-8005 CLOCK IS
Check both of these
