Leisure Cookmaster CM101NR Logo
A
Anonymous Posted on Jun 09, 2014
LEISURE CMTF99W COOKER DOOR REPAIRS
Oven door hinge brackets and pins bent door fell off, brackets and pins dont seem sturdy enough, removed top bracket and backplate fell out of line cant get door back on, less than a year installed warrenty just out.
1 Related Answer
dickandannet
Richard Warren
  • 2548 Answers
  • Posted on Jul 20, 2014
SOURCE: What do I need to do to screw the oven door back to my leisure Alta cooker? Any suggestions?
Try hooking the plate with a piece of wire and pull it close to the hole's,then get a strong magnet and put next to the screw holes,it might hold the plate till you get the screws started.
Testimonial: "Thanks Richard. I'll try this but the plates are right at the bottom so will be tricky"
Oven door on my Leisure Cookmaster101 wont close tight enough , how do I correct this problem?
If it's as old as ours the holes the hinge pins locate in have enlarged over time. This makes them sloppy. If you lift the door, is there a lot of up n down movement. Not closing properly will make the coven less efficient. I'm in the process of researching the parts required before Xmas. So we don't have a cooker failure on the big day??
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Hi. Just need to know if the oven door is adjustable on our AEG electric double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same...
there will be a slight adjustment that can be done if you undo any screws or bolts holding the door , no need to take them completely out but just enough to re position the door , make sure there are no hinges that are bent .
Nov 18, 2017 • AEG Ovens
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Door came off the hinge
    These Videos will help with your cooker problem.
    If you need more video help on appliance repairs visit our Video Tutorial Library at our website
    1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
    2 How to change and fit oven door hinges.
    We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
    We also supply all the Parts you need for Repairing your cooker oven Door.
    Oven Door Hinge Spare Parts
    Oven Door Glass panels
    Cooker Door Handels ETC
    Cooker Door Catches ETC
    Cooker & Oven Door Seal / Gaskets
    Remember to Leave feed Back and pass our site on to your Friends:
    Our Shop http://www.apart4u.co.uk
    Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
    Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
    we should be able to help if you contact the office
    Mar 04, 2010 • Ovens
    Loose beko oven door ??
    CHECK FOR A SLOT WHERE THE HINGE GOES INTO IT MABE YOU CANT SEE IT BECAUSE IT MIGHT BE CLOGED WITH FAT CLEAN WITH SOAPY WATER AND FIT THE PIN INTO THE SLOT AND IT SHOULD BE FIXED,
    Nov 29, 2009 • Ovens
    2helpful
    3answers
    My oven door does not close tight
    These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
    It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
    Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
    Then reassemble.
    My door now feels like a new one even though it is 15 years old.
    2answers
    Glass oven door fell off
    There is probably a retaining bracket behind cooker front panel you will probably have to remove a side panel to access the retaining bracket.
    Please rate my solution.
    Thanks.
    Jul 16, 2009 • Ovens
    1helpful
    Oven door closure
    I had the same problem, the door will come off by opening it partially and lifting it up off the hinge brackets. Be careful, because the brackets are spring loaded and will snap shut when the door is removed. You will find a hinge pin with a spring clip at the bottom of the hinge. It's likely that the spring clip has come off of one of the hinges and the pin fell out. You can find the drawings and part number(s) on the "partsdirect" website using your model number, and even order them there.
    Jun 27, 2008 • Ovens
    Top Leisure Kitchen Ranges Experts
    Paul Carew
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
