When using edit to set up tones, I've found that I must have the compressor on (even if it is set to 0) on in order to get any volume at all. Then I found out the other day when I actually made a mistake an clicked the floorboard to MANUAL that is was louder than heck,but with the effects in, I have to turn the amp almost all the way up to get any volume at all. Thoughts?
SOURCE: Amp goes quiet after working fine for about 15-20 min.
If you are not a tech, I suggest you send it to one. If you are, after signal-dropout spray output transistors (one at a time) with component cooler (freeze spray). If still no results, go to the other transistors & IC's. Chances are that will pinpoint faulty component.
SOURCE: Having a few problems with
Sounds a lot like a poor connection on a PCB connector. A whack on the side may produce a similar result, then you know it is something like this. If so, it will be even a challenge for a tech to pinpoint.
