Question about Maytag MAH8700A Front Load Washer
How do you unclog drain on washer so it will drain again?
Washed rug with rubberized backing which disintegrated and now washer won't drain.
    New Friend:
  • 3 Answers
You need to open the water pump to see if it is clogged with any thing causing the obstruction for not draining.
Posted on Jun 12, 2014
SOURCE:
SOURCE: does not drain
Do not open from behind! First drain as much water from the drum as possible. and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter.
BTW - on the back of the front panel are the SERVICE INSTRUCTIONS with a warning - Technicians only. The manufacturer keeps the instructions for doing this and many other simple fixes 'secret' so that their techs can make $!!!! There are no instructions whatsever in the consumer instructions about removing the front panel or cleaning out the filter.
Posted on Apr 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Washed a rug with rubber backing that came off
Remove and clean the drain pump.
Posted on Apr 30, 2009
  • 306 Answers
SOURCE: WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART.
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
Posted on May 05, 2009
  • 67 Answers
SOURCE: I clogged my washer drain...
follow the discharge hose into the washer body --- the trap will be at the housing the hose connects to --- not a big job. be sure to unplug the machine and hand bail the standing water out of the basket. keep a sponge and rags with a pail for the water in the trap and hose. no special tools, but it will be metric
Posted on Jun 20, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Posted on Oct 04, 2009
Washed a small bath rug in the machine. The piece of rug said it was washing machine safe. The rug broke apart as I was washing it and now the washing maching will not drain. I have to open the bottom...
This becomes a long drawn out process in which you have to remove the pump and the entire drain line and wash all the backing out of the machine also you have to remove the lines that go from the tub to the pump as well and even after you finish cleaning out the drain system you still will have more pieces stuck inside the tub area that you have to clean out as well. Easiest way take the machine outside or to an area you can use a hose on the unit where after you disassemble the entire pump area that you can wash the tub out of all the small pieces of the rug backing I had the unfortunate repair of doing this to someones rubber backed rug cept it took all the rubber off the back of the rug. It took about 3 hours with hooking and rehooking the drain lines and unclogging them over and over due to this unit I was working on was in a basement and no access to a hose If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
p.s do this repair yourself a repair technician would charge about 200 to repair the unit due to the amount of time
Apr 28, 2011 | Samsung Washing Machines
I have an LG front loading washer, Model WM2050. I washed 2 small area rugs and the backings disintegrated. I cleaned out the tub and gasket, but I am afraid to run the washer for fear I will ruin it...
If the backings disintegrated and you do not see them in the tub, you'll need to check the clean out on the unit, on the bottom-left corner, this cap will unscrew and you can pull out the clean out filter, and see. If you have tons of debris in there, you may have a nasty clog, and most likely didn't make it any further than the clean out. It may have even burned the drain motor out, and that may also need replacement.
Mar 12, 2011 | Washing Machines
Washing machine is shutting off after a rug was washed in it...I didn't know it would desinigrate now it won't drain and keeps shutting itself off.....what can I do?
time to empty out the pump filter trap .....never wash rubber backed rugs in any washer!!!! we call them washer brakers ....
Jan 28, 2011 | GE Washing Machines
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
I have a bath mat that I washed in my duet washer successfully twice. Now when the cycle is complete the bath mat is drenched and apparatly no water was extracted from it. I'm frustrated. Another frequent...
Out of balance with wet, heavy rug.
Bathmat is border-line on being excessively heavy (wet)
Do not use in washer. The fact that you got away with it before is your hint NOT to do this again or else bigger problems???
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag MAH8700A Front Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
