What did you do to reposition the handlebars, did you take the right side perch and switch housing apart or off. If so you may have pinched or otherwise damaged the wires or you may have damaged the run/stop switch or the start switch. If you had other wires apart or exposed check them for pinching or other damage as well. If you do not hear the starter relay click you have damaged something in the wiring before it and likley it is in the switch housing or the handlebars themselves.
SOURCE: Handlebar Limitations For Super Glide
Stupid site just deleted my answer. I'll just say 6" pullback risers. Don't get mini apes because you'll have to buy the control cables and lines for an FDWG.
Try aftermarket akin to a De Luxe riser and clamp setup. It'll still cost you.
Carlos
SOURCE: does anyone know how to program the keyless remote
The HD alarm is REALLY complicated. 10 pages in the manual. I'd have the dealer order you an owner's manual for about $20. If you just can't start the bike, one long push on the remote sets it and 2 quick clicks turn it off.
SOURCE: 2005 HD Electra Glide Ultra Classic - Cruse
It is telling you to ditch the beast and buy a BMW.
SOURCE: My check engine light goes on sometimes and then
on your dash is the button to check your milage. push it in and hold it down until your codes come up. some of the numbers it will go through will only be ecm numbers
Testimonial: "exactly what I needed. Thanks,"
SOURCE: 2008 FLHX Street Glide: no problem, just asking what DOT # of brake fluid ...
DOT 4 brake fluid
