Tablets & eReaders Logo
M
Marlene Posted on Jun 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mynextbook says my storage is busy what do i do
When I try to take a picture it pops up that my storage is busy
Thomas Smithbrother
Level 3:
Top Expert:
  • Tablets & eR... Master 3,698 Answers
  • Posted on Jun 09, 2014
Thomas Smithbrother
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957183
Points
10318
Computer.howstuffworks.com/.../nextbook-tabl..
consider reading the above.
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Install snapchat
Start to delete unnecessary items, transfer pictures to an alternative storage device, reboot/restart phone and try again.
I get this message when trying to connect to wi fi. But I have an sd card and storage is fine?
You have an SD card, and there's plenty of space there, but . . .
The main storage in your device is full. Move some files/pictures, etc to your SD card, and the problem will go away.
The SD card and the internal storage are separate, and your device can't move stuff automatically.
1helpful
2answers
Why does my iPad indicate no storage left?
You will have to remove pictures, videos and apps that you are not using any more. You can sync the ipad to a pc or mac and save the pictures and videos you want.The icloud is tied to your apple id. go to this link ( iCloud ) and sign in with the same info you use to sign in to the app store. The icloud gives you free online storage for pictures videos and documents that you have on the ipad.
2answers
How can I retrieve my pictures back that I had taken with my tablet camera ? For some odd reason my tablet keeps erasing me pictures .
You can have them back by Photo recovery process as your photos has been erased so the process would be this only. Also check your SD OR memory card may be storage space it not there for new addons. I suggest can suggest you services for picture recovery who can also guide you for the further precautions to be taken after retrieval. Digital Photo Recovery services to recover lost deleted or formatted...
3answers
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Why does pop up's keep occurring
because that's what happens what kind of pop ups
Android.process.acore
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
I would like to know how to transfer my pictures from my tablet to my computer
You should plug your USB cable into both your tablet and computer it should initialize a sync as well as give you the options available for viewing or transferring pictures. Another way is after plugging it into the computer go into the computer menu click the tab that says computer you should see your tablet synced as a removable storage unit open your tablets storage and locate your pictures in your device or on your SD card depending on what your default storage settings are then select the pictures you wish to transfer or copy and open up the designated file on your computer where you would like them to be transferred to and begin. I have an ASUS tablet and this is the method I use .If all else fails please go to you tube type the brand of your tablet and the phrase. How to transfer pictures. Hope this helps.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
