SOURCE: Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
SOURCE: DAMAGED CRYSTAL
Send a photo so I can see if the crystal needs to be custom cut or whether a generic will work. [email protected] Thanks.
Sarvadrk
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
