General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
A
Anonymous Posted on Jun 09, 2014
Problem GE WAETER FILTERS - General Electric GE SmartWater Household Water Filtration System - GNWH38F
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Nov 10, 2017
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79088
Points
573
This is a statement not a question.
GE Smart Water under sink dual water filters replaced. Very little water pressure. I have reinstalled them, no improvement. I have been replacing these filters for 5 years and have not encounerted this...
Hi jbboggeri,
Welcome to fixya!
I would go ahead and open the new set and install them. If you get pressure, you know the others were bad and can send them back for a refund.
If there is no change, you can always put them away and use them again later.
Please reply back and let me know how it went. Thanks,
Handie Andie
I need a handle for the Smart Water System
Here is the web page for GE. You will probably have to replace the whole faucet. When you call have the model # available for your system so they can supply the appropriate faucet. You may as well order more filters as they will be less expensive ordering on-line. These filters should really be changed every 6 months.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Dual_and_Single_Stage_Water_Filtration
These faucets are relatively easy to replace for the do it yourselfer.
RJ
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
I have a whole house water filter that uses a 30 micron FXHSC filter. the last two filters have come apart and sent fiber through the water lines in the house
I would shop around for a different water filter supplier...there is no reason ofr that happening unless you are not changing the filters regularly...like once a month...
most filters are a standard size and it should be easy to get them somewhere else...
heatman101
How do you change the GE smart water filters?
This page might help with changing it, as different models vary.
Installed a complete Vitasalus water fitraion system. From our pond to our home. The water is still very dirty. Don't know what else to do. Help?
put more filters in the line from diferend kind water filterd tru 3 or 4 filters are more clean you have to now whath are the thinks making the water dirty like yron or ????
Low water pressure is diminished after replaced 2 filters in a month. plumber tested to see if water is fully flowing.
Does this mean that you are now having the right pressure? Since the filters are changed, water should
now flow. Is it all systems go?, that is assuming that
your pipelines are not clogged.
1helpful
My ge smartwater was running very slow ao i changed all three filters, now it runs normally for a couple of seconds then it just trickels out.
The tank was full of water . The blatter in the tank was empty so I pumped six pounds of air into it and it works great.
Top General Electric Water Heaters Experts
Paul Carew
ADMIN Eric
ADMIN Eric
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
