Question about Razor MX500 Dirt Rocket
Razor Mx500 runs fine then stops
The batteries are fully charged, rides for a while (times vary sometimes five minutes, sometimes 20) then it cuts off. There are no sounds except the normal throttle click. Wait a few minutes, hit the throttle and it works. Then it doesn't. Then it does. Any idea what could cause this? Thanks.
5 Suggested Answers
6ya staff
SOURCE:
jason reynolds
  • 70 Answers
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Posted on Apr 03, 2010
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: my razor mx500 is not
Look hard for loose wires. Start with the on off switch. Make sure all are plugged up. The fuse should be accessible without taking things apart. Water is a major enemy of the solid state box the wires go into before they go to the battery.
Posted on Aug 23, 2010
karinb129
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: The MX500 wont start. The light says the battery
Although you alternator may be charging, the battery may not be accepting the charge or holding it. Have the battery tested under load, but I think that you are going to find you will need to replace it.
Posted on May 09, 2011
Testimonial: "Thanks for the quick feedback. I appreciate your help as I am a novice at this."
My razor mx500 just instantly stopped running when I was riding up a hill, it was on a full charge could it be a blown fuse or multiple blown fuses?
weight always play a role when a rider is going up hill. If the rider is over the weight limit or near the weight limit, the motor works very hard and need more power/electricity from the battery, for which the motor runs hot and the 25 to 30 amp fuse would break, shutting down all power instantly.always check the fuse first when all power is lost before anything else....
Mar 13, 2016 | Motorcycles
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
May 21, 2014 | Razor MX500 Dirt Rocket
How long can the Razor MX500 Dirt Rocket be ridden after charged?
Run time depends on a few things, including the weight of the rider, the terrain being riden over and the condition of the bike.
For example, a light rider riding on flat hard packed dirt or paved road with a bike that is in good mechanical condition - tires inflated to correct pressure, chain correctly adjusted/lubed, brakes adjusted, etc. - will have a longer run time than a heavier rider on soft undulating dirt with a bike that has not been maintained.
Generally you should be able get 40-45 minutes out of a new battery.
Check out the trouble shooting guide and user manual if you are getting less than half and hour.
http://www.razorama.com/ownersmanuals.html
Jul 31, 2013 | Razor MX500 Dirt Rocket
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
I can only get about 5 minutes of riding.either the battery or the charger might be broken.i relly dont know what to do.i need help
If you take the battery into a car part store like Schuck's or Napa, they will test the battery for free. They will test it to see if it will hold a charge. If the battery doesn't hold a charge, then the battery needs to be replaced. If the battery holds a charge, then your charger needs to be replaced.
May 22, 2010 | Razor MX500 Dirt Rocket
Apr 02, 2010 | Razor MX500 Dirt Rocket
Battery shows a full charge but wheels won't turn while grounded
theres nly 2 things at work here in my opinion, the battery and the charger, if this bike is of any age chances are the battery is no longer good, it may read ok with the meter but when you put it under a oad like trying to ride it it may go to 0000 see if you can mete it under aload
Mar 14, 2009 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
177 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
