SOURCE: H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
SOURCE: I have a new droid by motorola and an old h500
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
