Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
From the manual: This camera does not allow you to insert the shooting date into an image while shooting (date stamping). However you can use the following method to imprint the date while printing.
Set with the camera's Digital Print Order Format (DPOF) function. Set [Date] option to [On] in [Print Settings] in the Print menu.
Connect the camera to a printer and imprint the date. See the Direct Print User Guide.
Insert a memory card into the printer and imprint the date. See your printer user guide.
Use the supplied software. See the Software Starter Guide.
You can download the manual and guides and more from the manufacturer's web site at http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_pro_series/powershot_g10#BrochuresAndManuals
Check to see that both cameras are set to the same settings. For example, turn both cameras to manual and set them both to the same aperture, ISO, and shutter speed. This could account for the difference in brightness if one is set to be more light sensitive than the other.
From the shooting menu, select "Color." You can select "B&W" for black-and-white, or "Sepia" for the old-fashioned brownish look. For full details look in the manual under "Shooting menu." It's on page 32 of the online version of the manual available on the manufacturer's web site at http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW70
Start with using the program mode. Press function setting. On left menu select the 2nd button whic is "My colors". Now, at the bottom menu go about four spaces, which should be BW. If you want great videos on the G10 visit the following site; www.lbguides.com
