Forest River 2008 Flagstaff Classic 625D Logo
A
Anonymous Posted on Jun 08, 2014
Why water leak between tank and faucet forest river flagstaff classic 625d?
We took our new to us Forest River 2008 Flagstaff Classic 625D out for the first time this weekend and we ended up with a flood while attempting to hook up our water. We have no manual, and haven't been able to find one online. Seems like we are missing something between the tank and the faucet??? Hose to tank seems fine, we do have a water filter, but can't seem to see anything there either. Any help would be wonderful.
Red River RV Repair
Level 2:
Sergeant:
  • Expert 405 Answers
  • Posted on Jul 22, 2014
Red River RV Repair
Expert
Level 2:
Sergeant:
Answers
405
Questions
0
Helped
164188
Points
581
You will not find a plumbing diagram since they are not published. Were you connected to the city water or were you using the fresh water tank? You will basically have to start at the input point and follow the water lines until you locate the leak. Identify what is leaking and replace. It is possible that a water fitting has either popped loose or cracked from freezing.
2answers
Where is fresh water drain plug for 2022 flagstaff classic 832rksb? RV trailer
find tank see bottom of tank see drains if there at all.
if not we pump it dry
2answers
2015 Forest River Flagstaff T19QBHW Wiring Issues
I have seen disconnected wires in pictures of used units. It may be for uninstalled options. Unfortunately, it seems like mfg don't want you to DIY repairs so the best you can do is make your own diagram.
Aug 19, 2017 • RVs
2answers
Where can I find an owners manual for a 2012 flagstaff micro lite 21fbrs? I just bought this camper and I need manual. Thanks & God bless! John Z
Well, as you probably already know Forest River only carries the on-line manuals for the last three model years. However, I'd send them an email request and see if they can dig one up out of their archives.
Another good place to try would be owners group forums.
Owners manual for 1997 flagstaf popup camper
You will have to contact Flagstaff, but you also need the actual model number of your camper. You can also google a manual for a 97 Flagstaff model # _______
Sep 13, 2014 • RVs
Manual for forest river rv manuals
Google it...."download manual forest river RV". You should find it out there in the world wide web.
How can i access the drive unit for the bedroom slide on my 2009 Forest River Flagstaff Classic Super Lite FKBSS?
If the bed is on the slide, more than likely the mechanism is under it. If not then it should be outside in the under belly.
I would check for voltage at the switch first.
Water tank says empty but it is full
Do you have a tank heater on the tank? If not, you may want to get one to prevent the tank from freezing and busting. Next, there is a small diode inline and it may have failed which will give a false reading.
Where can i find the water pump
Typically the pump won't be too far from the city water inlet on the inside
Manual
Contact your local retailer directly or online here:
Top Forest River RVs Experts
Renee Knafel-Bullock
Larry Ng
Larry Ng
Are you a Forest River RVs Expert? Answer questions, earn points and help others
