Sony Bravia XBR-Series KDL-46XBR4 46-Inch 1080p LCD HDTV Logo
A
Anonymous Posted on Jun 08, 2014
Sony xbr lcd flicker double picture - Sony Bravia XBR-Series KDL-46XBR4 46-Inch 1080p LCD HDTV
Back2life Electronics
Level 3:
  • Sony Master 933 Answers
  • Posted on Jun 10, 2014
Sony Master
Level 3:
Answers
933
Questions
6
Helped
274565
Points
2189
I'm a 100% certain your LCD panel is bad, I've run across a lot of Sony/Samsung's with the same problem. It can be fixed but involves taking the TV apart. I have 5 flat screens in my home, 3 of them had the same problem yours had, I patched them and they are working fine! A replacement panel will cost more than a new TV set so that's not an option. If you do no wish to fix, I would suggest putting it on Craigslist as a parts unit, someone will buy it. If I have been a help to you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
4 Related Answers
Anonymous
  • 13 Answers
  • Posted on Mar 27, 2008
SOURCE: SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Anonymous
  • 81 Answers
  • Posted on Apr 08, 2008
SOURCE: Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Azrael SRL
  • 11800 Answers
  • Posted on Sep 03, 2011
SOURCE: Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
Glenn Montalbano
  • 3 Answers
  • Posted on Aug 06, 2013
SOURCE: Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Flickering issues with Sony XBR-HX929 TV
customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them
We have a 52" Sony
This problems alway the causing of the board,that call the T-CON decodering board it is dying.This T-CON decodering board alway sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a rrefurbish T-CON decodering board for the replacement.
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Exactly the same problem and we bought ours in Jan 08
The screen has failed. Well specifically one of the small baords attached to the edge of the actual LCD panel itself. It is not replaceable on it's own only with the LCD panel itself.
If the TV is under warranty, Sony is 3 years I think, then take it back.
1helpful
Blue line across top of my Sony XBR 60
KDF-60XBR950 replaced bulb, but no picture. It DOES have a solid green light when on.
1helpful
I have a Sony Bravia XBR 46". It is 18 months old. The left 20% of the picture is fine, but the right 80% flickers in horizontal bands. Pushing back lightly on the upper right corner of the bezel and...
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
1helpful
Sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
