This treadmill has been sitting up for about a year, when last use it all parts work. now only lights up and most parts do not move the treadmill , etc.
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
I had a problem with my Nordic track and I ended up calling the Nordick track service. No one on the internet really seemed to have my issue buttoned down. They were GREAT!! 1-877-993-7999. They help you troubleshoot to find the problem and then you can order the parts. Hope this helps.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
SOURCE: Treadmill won't start. Console works but when
If the console takes
batteries, replace them. If this does not work or your console does not require
batteries, check the reed switch or optic sensor. Reed Switch:
Unplug the treadmill and remove the motor hood cover. The reed switch is mounted
on the frame next to the front roller pulley. There is a magnet glued into the
front roller pulley. When adjusting the reed switch, make sure it is pointing
directly at the magnet. Move the tip of the reed switch within 1/8" of the
magnet. Also, check to see that the wire is not damaged, and is connected to
the console
Optic Sensor: Unplug the treadmill and remove the motor hood
cover. The optic disk and sensor are located either at the end of the motor or
the right hand side of the front roller. The optic disk spins between two
sensors on the optic switch. The disk must spin freely without touching either
sensor. The sensors can be moved by loosening the adjustment bolt holding the
switch to its bracket. The switch can then be slid. Center the disk.
Remember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
The Steps
for Newer Style Console Calibration:
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
