JBL Marine Audio Wired Remote Logo
Posted on Jun 26, 2009
The remote splitter box is broke, need to replace where to buy
Need to buy a replacement
Call 1-800-remotes, they have many remote replacements. But maybe cost just as much. They also sell Universal Remotes that may help and is way cheaper than an original. You buy them @ Radio Shack, or Rite Aide.
I need the code for this converter box so i can use my universal control since the old controll broke
This is a recent technalogy,doesn't have codes for any universal remotes yet.Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Is there a suitable splitter I can use on the RF out on my sky HD box to feed 3 bedrooms allowing digital freeview and magic eye use?
You better off buying a four way distribution amp instead of using a splitter
Make sure the amp is sky and magic eye friendly
3helpful
3answers
RCA projection P46732BA no power and arcing sound
The High Voltage Splitter is the cause of this and replacing it should fix the problem. Their should not be a shock hazard once power is diconnected. But just incase, ground each of the anode leads from the crts to ground. That should take care of any HV charge from the CRTS. Do make a note of which wire went went where, that is important. When you get the new HV Splitter, you will need to transfer the small board that is mounted on the old Splitter. Again, be aware of where the wires hook up to it and you will be fine.
Hope this helps,
Skyassoc
1helpful
2answers
MAGNAVOX DTV DIGITAL TO ANALOG CONVERTER
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12543595690260&smodel=TB100MW9&brand_pn=MAGNAVOX_TB100MW9
5helpful
2answers
How to operate 2 tv using one set top box with two differt remote contr
coax out on ctv box to coax splitter. coax to each tv from splitter. u will have the same channel on both tv's...otherwise pay for another cable box.
Xbox 360
well there are 2 other ports on the 360. two in front and one in back. you could buy a powered splitter to run more than two usb devices on the same hub.
3answers
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Top JBL Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a JBL Boating Expert? Answer questions, earn points and help others
