Lands Phones Logo
A
Anonymous Posted on Jun 08, 2014
GE Cordless/answerer base station
Model no 2-9740A
5 Related Answers
DemonShane
  • Posted on Jan 15, 2008
SOURCE: ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Anonymous
  • 106 Answers
  • Posted on Feb 10, 2008
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Anonymous
  • Posted on May 30, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Anonymous
  • Posted on Mar 03, 2009
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Anonymous
  • Posted on Apr 25, 2009
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
I do not know how to get my messages.
press the play button on the base station
If you want to be able to ring the base station and get messages then that is a more complex answer and requires information like what cordless phone you are using, what model make etc as there are different ways of setting up the system
comment on the details
I can help if it is a uniden dect 6.0
Please register on the screen
When you see this 'register' message, it means that that particular DECT handset must be registred to the selected 'Base' station: please consult your User manual/guide for the steps by steps instruction on how to register a new handset to your base station for the specific compatible model(s).
Hope it helps.
Wish to use the telephone company answering system how do I turn
There is a button marked "ANS ON/OFF" right on the base to control the answering machine function. The display shows "--" when answering is off, otherwise it shows the number of messages.
The manual says you can delete messages one at a time from the handset, or all at once or one at a time from the base.
You can download the manual from GE here:
http://www.home-electronics.net/ge/pc/IB/25942GE2_IB.pdf
1helpful
3answers
Do Not Disturb is on phone does not ring
I had this happen. After searching around here and elsewhere, I decided to look at the base station for the phone instead of the phone itself. In the lower right corner of the base station is a button labeled "Do Not Disturb" in inset print. The red LED above it was lit. I pressed the button and this cleared the problem.
2helpful
3answers
How do I remove the do not remove the do not disturb setting?
thank you Now I feel dumb I can't belive I didn't see that
2helpful
Ge cordless phone station 2 shows unavailable
Audioline cordless phone
answering machine not working on the base station
2answers
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
