We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
SOURCE: How do I register a Shark Steam Iron on line
Follow the link to register you Shark Steam Iron
https://secure.prodregister.com/euro-pro/hhappliance/yqd_1.shtml
