SOURCE: Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
SOURCE: Starts to steam and water light flashes. No
I have 2 also and I use good water but I set mine on the max (all the lights lite) I use to work on these machines and they are good but water is the culpret on most issues with this machine. sweet water has a lot of calcium in it and that can plug the tube going through the boiler. We replaced 3 boilers on these new type boilers because they will plug up with calcium and when they plug completely they have to be replaced. We fould that if you descale more often than needed you have less troubles with the boiler. I have a Digital Italia that has over 18,000 coffees on it and still has the same boiler. I descale all my machines at about 400 coffees.
