SOURCE: I am having htc wildfire.
U CAN DOWNLOAD THE SOFTWARE FROM THE BELOW HTC SITE
http://www.htc.com/www/SupportDownload.aspx?p_id=316&cat=3&dl_id=1058
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you..
Please rate the answer.
Thanks...
SOURCE: i have a htc wildfire s how do i get android app
Plz use this link to download free apps for HTC wildfire http://www.mobilerated.com/dir/Applications/Apps/?device=HTC+Wildfire&sort=Popularity
SOURCE: How do I enable javascript
The option for this is found inside your web browsers settings. While in the browser, press the "Menu" button. Then select "More" and then press "settings". While in settings just click on the option that says "Enable JavaScript" and then you're done!
Good luck! And please, if you do find this answer helpful give it thumbs up :)
SOURCE: How do I put my
Go to Settings->Applications->Manage applications. At the Downloaded tab, tap on the application of choice, and tap "Move to SD card" button under the Storage section.
Please note that not all applications can be moved (disabled "Move to SD card" button) due to some Android system requirements. If an application is already moved, the button will now be named "Move to phone". You can also select the "On SD card" tab to view apps already moved.
Also, there is a free app by Sam Lu available at the Android Market.
