Acer AL2671W 26 in. LCD Television Logo
p
penda enongene collins Posted on Jun 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i solve the problem of my Qsat that moves channels and press menu on its own
Level 3:
Top Expert:
  • Acer Master 76,851 Answers
  • Posted on Jun 09, 2014
Acer Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007550
Points
237762
Sounds like main system control memory IC fault. Contact any service technician. http://electronicshelponline.blogspot.com/
How to unlock nova TV
I am sharing a few steps with you. This steps solved your problem easily. Hopefully these steps solved your problem .
Steps:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To unlock all channels:
Select Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Unlock All, or
select specific channel(s) that you'd like to unlock.
Scan for channels
press menu to bring up the onscreen menu, then us the up/down/ sideways buttons to move around the screen menu
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
MY TVM2515 DOES NOT HAVE A MANUAL OR A REMOTE NEED TO SELECT ENGLISH AS THE PRIMARY LANGUAGE---HOW DO I DO THIS?
Press the menu button use the channel up and down buttons to move to the language portion of the menu. press the menu button again to select the language field then use the channel up and down buttons to toggle through till you find English then press the menu button again and that should do the trick.
Mar 23, 2012 • GPS
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
4helpful
Samsung le26r74bd won't retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
15helpful
3answers
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
5helpful
2answers
Can't find button on tv to change source in order to play dvd
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this:
Press the "MENU" button on the TV.
Press "CH Down" until "Channel" is highlighted, and "MENU" to select it.
Press "CH Down" to highlight "List and Labels", and "MENU" to select it.
Press "CH Down" to go below channel 1, you should see "FRNT" displayed.
Press "MENU" to get out of the Menu system.
You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
5helpful
2answers
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to [email protected]
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
