Question about Razor MX500 Dirt Rocket
Razor mx500 loses power
The batteries are fully charged. After riding for a bit (times vary - 5 min, 10 min) the bike stops. Throttle only clicks but there is no power. Typically if we wait a few minutes it will run again but then it cuts off. Then runs. Then cuts off. Vicious cycle. Any help would be appreciated. Thanks.
SOURCE:
SOURCE: Early model Razor MX-500. Replaced motor, control
the back wheel won't move it try to move but it won't it's making a loud noise.every time you give it gas.what could that be...
Posted on Dec 26, 2009
  • 70 Answers
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Posted on Apr 03, 2010
woodchuck789
  • 4070 Answers
SOURCE: my razor mx500 is not
Look hard for loose wires. Start with the on off switch. Make sure all are plugged up. The fuse should be accessible without taking things apart. Water is a major enemy of the solid state box the wires go into before they go to the battery.
Posted on Aug 23, 2010
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
erickedubbs
  • 15 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
May 21, 2014 | Razor MX500 Dirt Rocket
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
How long can the Razor MX500 Dirt Rocket be ridden after charged?
Run time depends on a few things, including the weight of the rider, the terrain being riden over and the condition of the bike.
For example, a light rider riding on flat hard packed dirt or paved road with a bike that is in good mechanical condition - tires inflated to correct pressure, chain correctly adjusted/lubed, brakes adjusted, etc. - will have a longer run time than a heavier rider on soft undulating dirt with a bike that has not been maintained.
Generally you should be able get 40-45 minutes out of a new battery.
Check out the trouble shooting guide and user manual if you are getting less than half and hour.
http://www.razorama.com/ownersmanuals.html
Jul 31, 2013 | Razor MX500 Dirt Rocket
Batteries are charged and the bike doesnt work any ideas on what it might be and batteries are new
yes! if that's the case ,the motor is the culprit.there are 4 things that make our bike run..the a good charger, batteries, the throttle, and the motor. now that you singled out your battery and charger ,you have the throttle and your motor..1st check your throttle & make sure it stops @ a1/4 twist.check all connections, then do an extencive check of your motor for moisture or water/signs of it being wet/riding in the rain..which is a big No-No../no rain No snow, No drizzle,and no puddles clean or muddy..it is not a gas bike....remember!great tip!
Dec 20, 2012 | Razor MX500 Dirt Rocket
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
Apr 02, 2010 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
180 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
