I'm not sure what a flywheel seal is but I'm going to tell you to just remove the unit. I know it seems intimidating but these things are so super easy to remove you'll be amazed. From there you can dismantle it or replace it. There really isn't a whole lot to them. You'll see : )
Look for a six-sided (hex) hole at the center of the bottom of the disposer.
If you find such a hex hole, look for a hex wrench, usually stored in a pouch on or near the disposer. If you don't find one there or have one in your toolbox, you will need to purchase one. Don't use a screwdriver or other tool because it can damage the hex hole.
To free the flywheel, insert the hex wrench in the hex hole and rotate it in a circle in both directions.
2) When disposal rusts out, or bearing seal breaks, the disposal begins to leak from bottom. It might be possible to take apart and replace bearing, if you can find that specific part and have specific tools and sealer needed to seal the bearing and repair rusted disposal. Probably easier to replace disposal.
The motor start winding has gone bad, or capacitor burned out. Generally disposals are replaced when motor goes bad. Mostly because the disposal is sealed unit and cannot be easily disassembled. If you have local motor-repair guy, who has disposal bearing parts, and can get the disposal apart, then repair might be possible... but the bearing seal would be hard to replace. Copy following link for replacing garbage disposal with tips from when I did apartment maintenance. http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about Garbagedisposal and possibly yours, from repairto trouble shooting it. b>http://home.howstuffworks.com/how-to-repair-small-appliances7.htm Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Red reset button is located next to wire connection on disposal side.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
If blades are stuck, use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If it's leaking directly from the bottom, then it's the flywheel seal. For about $20 you can fix this by unplugging and disconnecting the garbage disposal from the sink, taking it apart and replacing the flywheel seal. I've had to do this only once in my entire life, so it is rare, but happens.
If the leaks comes from somewhere else and just happens to drip along the side and looks like it's coming from the bottom, then you've got problems with the installation. You may be able to fix these types of leaks by tightening the mounting bracket and/or hoses.
