Question about Compaq Presario 700 470024-192 Notebook
Sp36684 - Wireless LAN - Compaq Presario 700 470024-192 Notebook
  • Randal Lovelace Nov 26, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What are you asking exactly?
    Is this the model of Wireless LAN in that laptop, or I need a driver for this wireless LAN for this laptop? or I need to replace my wireless LAN and wanted to know if this one will work? Just need to clearly ask, in order that people can help you.
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
I hsve problem with wireless driver in toshiba satellite l455-S5000 in windows 7-32bit its done install wireless driver and windows see wireless lan realtek RTL8187B wireless 802.11b/g 54 Mbps but...
Intel Wireless LAN Driver for Windows 7 (32) Posted Date: 2016-09-21 ' Version: 12.4.1.11.0 ' Size: 4.43M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 1.0.0.196.0 ' Size: 21.82M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 8.0.0.144.1 ' Size: 21.79M Realtek LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 7.003.0522.2009 ' Size: 7.26M pls remove the back cover and check wireless card label and download the correct driver.
Oct 01, 2017 | Toshiba Satellite 1415-S105 Notebook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Presario V6000
2 things to try: go back on the HP website and request assistance from tech support; or go on Google and ask what you need to do to activate the wireless LAN. Check what the network settings are on your laptop 1st.
Sep 11, 2009 | Computers & Internet
Hp2220us product no:RP409UA#ABA
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36684.exe - wireless lan
if helped rate fixya if u have not the lan driver use nvidia nforce drivers
Jan 06, 2009 | HP Business Notebook 6515b - AMD Turion 64...
My Hp pavilion tx2000 cant play audio files,cant connect to net
Hi James
First, Sound drivers:
HP Pavilion tx2000 CTO Notebook Realtek High-Definition Audio Driver 6.0.1.5494 A from HP notebook
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38206.exe
and video drivers..
HP Pavilion tx2000z CTO Notebook NVIDIA GeForce Go 6150 Video Driver 7.15.11.5682 A
http://notebook.free-driver-download.com/url.php?id=TlRJeE5Eaz0&link=0
Now network:
HP Pavilion tx2000 CTO Notebook NVIDIA nForce Chipset/Network Driver 5.53 A
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38205.exe
and wireless!
This is an older WIFI driver that only works in XP, and in certain HP Pavilions, but try it.
and this is the Vista one that is correct for your laptop, it probably doesn't work in XP but if all else fails, you could try it. (You should really run Vista on it, I reckon)-----------------
HP Pavilion tx2000 CTO Notebook Broadcom Wireless LAN Driver 7.0 Windows Vista
http://notebook.free-driver-download.com/url.php?id=TlRJeE5EWT0&link=0
All support you need is here at HP Tech Support:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3650975
Good Luck
Merry Christmas
Chris (ziraffa)
Dec 23, 2008 | HP Sound Card
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
