Schwinn 430 Elliptical Trainer Logo
A
Anonymous Posted on Jun 07, 2014
My schwinn 460 does not power up when i connect the power adapter
Hi can someone please tell me what power supply I need for Health stream MB303 recumbent bike as it has been misplaced
the Healthstream MB303 recumbent bike requires a power supply with an input voltage of 90-132VAC, 50-60Hz and an output voltage of 9VDC, 1.5A.
You can purchase a replacement power adapter with these specifications from Schwinn's official website for $18.99
Replacement Power Adapter with 6-foot Cord ' Schwinn (schwinnfitness.com)
How can i get a power cord for my Swinn ex. bike?Estimated to be 5 Years old.
It would help to know what model bike You have because that model number can be given to any appliance parts dealer that You find locally, possibly even Sears, to get a replacement power adapter. I'm assuming Yours is like a small transformer that plugs into the wall outlet with a small cord that has a shiny metal pin on the end that plugs into Your Bike? Adapters for other Schwinn® and Nautilus® home fitness equipment can be ordered by phone at (800) 605-3369. Optional power adapter for the Schwinn® A40 elliptical, A10 and A15 upright bikes and A20 and A25 recumbent bikes. I hope that helps!
My schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced
2helpful
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
10helpful
2answers
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
fitnessrepairparts.com
This is where I am getting the AC parts for my 201.
Mar 21, 2009 • Cycling
I LOOKIN FOR AC ADAPTER FOR HP F370 PRINTER
Whenever I am need of power cords I use Ebay. Here is one for your system.
http://cgi.ebay.com/AC-Adapter-Fits-HP-DeskJet-DJ460-DJ-460-Printer_W0QQitemZ260290984216QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item260290984216&_trksid=p3286.c0.m14&_trkparms=72%3A1199|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
