I am sure you have tried this, but if not give it a go:-
Switch off both powerplugs and leave for 5 minutes..
Switch on the powerplug nearest the router without the LAN cable installed.
Wait for 2 minutes and switch on the other powerplug without the LAN cable being attached.
Now wait for another 2 minutes before plugging in the LAN cable
Now plug in the LAN cable at the router end.
After about 2 minutes, plug in the LAN cable at the remote end.
Good luck.
SOURCE: Netgear router - wont connect
In Netgear routers if the tick light is on that mean there are some issues in the router. Normal by resetting the router to factory default can be solve these issues. Please follow the steps below to reset the router.
1. Locate the reset hole at the back of the router.
2. Press the reset button with the help of pen or a pointed object for 15 seconds.
3. Take out the power cable without releasing the reset button.
4. Plug the power back cable without releasing the reset button.
5. Hold the button for 15 more seconds and then release it.
6. Take out the power and plug it back and check the status.
Regards,
Rashsih Sharma
