SOURCE: Print Master Gold 16 compatible with Windows 7?
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
SOURCE: print shop 20 pro publisher not working properly
Here is a link that will check compatibility, http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=print%20shop%20pro%20publisher%2023
You may want to uninstall the program and then install in compatibility mode, the link below will guide you through this,
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the above does not work, you may want to contact the software developers to see if any updates can be used to fix the problem.
