Vizio L32 32 in. LCD HDTV Logo
A
Anonymous Posted on Jun 07, 2014
Why is my vizio tv flickering?
Why is my vizio tv flickering like a strobe light after 20 min of use?
Back2life Electronics
Level 3:
  • Vizio Master 933 Answers
  • Posted on Jun 11, 2014
Vizio Master
Level 3:
Answers
933
Questions
6
Helped
274571
Points
2189
Either inverter board fault or power supply fault!
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 21, 2009
SOURCE: My vizio tv flashes like a strobe light
Sounds like your Backlight Inverter Board is going out, saw one on ebay for about $55 : ) have to get the one for your model tho...
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Oct 05, 2009
SOURCE: vizio television screen flickers like a strobe
lcd sets use florescent tubes to light the display and, a ballast to power the tubes just like the lights in an office ceiling.
the tubes are called cold cathodes and, the ballasts are called inverter boards. replace your inverter circuit board it connects by wires to the cold cathodes so; isn't hard to find.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 17, 2009
SOURCE: Flickering problem with Tv.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
PARTS: http://www.shopjimmy.com/catalogsearch/result/?q=vizio+l32
Please post back what you find.
Anonymous
  • 1961 Answers
  • Posted on Jun 03, 2010
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Testimonial: "Thanks again. :)"
Anonymous
  • 3 Answers
  • Posted on Jun 25, 2010
SOURCE: My Vizio VX42L is flashing like a strobe light.
Mine did the same thing. Remove the stand and back of the tv. Be careful with screen do not lay on hard surface and scratch. When you take the back off you will see a board on the left side and a board on the right side. They are labeled slave and master. Remove the ribbon cables and take board out. There are 2 capacitors on each board (about an inch long). These are probably all bad (ends bulged a little with black stuff on bulged end). Radio shack has them for less than $2.00 each. turn the board over and you can read the size of the capacitor. You need someone who can use solder wick and remove all four capacitors and solder in new ones. Notice how the capacitors are turned. Each one is labeled with a dash for negative. Make sure you bend new capacitor connectors the same and put back in the same way. Put the boards back in the tv and attach all ribbon cables. Put back and stand on. hook up your power and cable box and you are ready to watch tv with no more strobe. Me, my husband, and son did ours last week. I looked up the problem on the internet, husband removed stand & back, son with the steady hand did the soldering. Family project that went well for once.
Vizio M50-C1 strobing spots in the display.
A Vizio TV will flicker if there is a broken backlight, loose or faulty video cable or port, poor signal strength or incompatible display settings. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them. If you have any of these options available please turn all of them off to see if this resolves the display flickering. lickering and shorted leds causing dark spots are both symptoms of bad leds. You can try turning down the backlight level and see if the flickering stops. The ultimate solution may be to replace the LED strips.
Vizio e320i-a0 that flicker constantly
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
1helpful
Flickering Sanyo LCD TV
There is some dry solder/leaky or dry capacitor in the board. I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
In sound active the light seems to be reacting to the noise of the bulb "ticking." But I do not know if that is the issue, in sound active it will randomly go off and then freak out and flicker...
There should be a gain control for the sound... they are often a little black shaft without a knob that you can turn down the sensitivity. That should solve the problem.
Flickers off on when turning on tv
Sounds like you have some capacitors that are leaking on your power supply. If so, each time it will take longer and longer for your tv to come on. A local shop should be able to replace them for around 100 bucks.
I've got a 37" LCD made by Vizio. After about twenty min. the screen start to flutter or flicker like a strobe light. Power on the unit stays on while this occures. What cani do to fix this?
I am having the same issue, I think the best solution is to replace the inverter slave and master boards. These are the circuits that controls the backlight and causes the flickering when they are malfuctioning.
4helpful
Vizio television screen flickers like a strobe light
7helpful
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
