Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
A
Anonymous Posted on Jun 07, 2014
How to replace gear on oster golden a5 - Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 11, 2008
SOURCE: how to put oster golden a5 two speed head on
Go to: www.clipperrepair.com and look at the diagrams. It might help you. Also, I went to Oster's website and found help there with internal parts.
Anonymous
  • 1066 Answers
  • Posted on Mar 13, 2009
SOURCE: Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Anonymous
  • Posted on Apr 01, 2009
SOURCE: looking for switch wiring diagram for Oster Golden A5
You must put the new one in exactly as the old one came out. Sorry, no diagrams unless you are an authorized dealer. Most of our repairs are common sense. No books. My husband just replaced mine today. Plus one clipper wasn't the switch as I thought, but was a broken wire in the cord near the clipper that kept shorting.
Anonymous
  • 448 Answers
  • Posted on Oct 02, 2009
SOURCE: I have an Oster Golden A5 2 speed. How do I
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Anonymous
  • 448 Answers
  • Posted on Oct 03, 2009
SOURCE: Bought Oster Golden A5 clippers new but did not
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Oster problems. Golden a5 clipper
The blade driving lever is certainly supposed to move, if it isn't then take the cover off and check the cam gear, it's really easy to change it.
1helpful
I have an oster a5 clipper. The motor is running but the blades do not move .What can be the problem? What part do i need to buy?
Its possible the gear wheel which is located under the name plate has slipped, if you remove the plate, lever and drive link the gear will pull off.
Inspect the teeth on the gear if there are signs of damage or slipping this is likely to be the problem.
1helpful
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oster A5 clippers wont run
remove the gearbox cover (nameplate) make sur the worm gear from the armature is spinning when switched on, if not turn off there is an internal problem. if it does move then check the condition of the gear it may have some teeth missing.
Fixable A5 Clippers?
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon2.gif carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
1helpful
2answers
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
3helpful
2answers
2answers
Oster Clipper Bakelite Gear Keeps Stripping
Your armature feed threads are most likely worn. This will continue to wear gears out unless the armature is replaced. Any Oster factory service center such as ourselves should be able to help. John, Shavers World. 313-534-0736
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marc Messenger
Level 1 Expert
jws1013
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
