I just got a 2-way frs/gmrs wristwatch radio model # x32x-2 and can not get them to turn on ? I have tryed to plug them in with the charger but do not get anything on the screen will not charge can you help me out . Thank you
Re: I just got a 2-way frs/gmrs wristwatch radio model #...
Check to make sure the batteries are installed correctly. Many times they have an insulator placed between the contacts to keep them from running down.
This unit transmits on FRS/GMRS channels. Please see page 19 of the user manual available from here: http://www.scribd.com/doc/3783989/Bellsouth-2231-frs-gmrs-radio-instructions
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
The Hi and Low power are built into the radio and is dependent on the frequency/ channel you are on. Hi power is 1 Watt and Low power is .5 Watt. The radio is GMRS and FRS. The FRS are low power and the GMRS are Hi power.
Channels 1-14 are FRS frequencies and Low power.
Channels 15-22 are High power and are GMRS frequencies.
FRS = Family Radio Service.
GMRS = General Mobile Radio Service.
If you have any comments please feel free to leave them here.
You didn't mention a model number, so I don't know if your radio is an FRS or FRS/GMRS model. GMRS channels have more power output than FRS does, but GMRS also requires a license for operation. Other than that, the frequencies are so close together that there is no distance advantage gained by changing channels. The manufacturer's distance claims on these radios are pure advertising gimmicks - the radios are line-of-sight only, so if there's anything between the transmitter and receiver, the signal will not get through.
All gmrs radios also have frs frequencies in them. The frequencies are staggered.....1 frs....1 gmrs....1 frs....gmrs etc etc.
The only difference between frs and gmrs is power.... you are allowed to use more power on gmrs freq. So thats why they have more range. But the frequencies are right beside each other.
I would be surprised if your friends radio did not have frs channels in it also.
They should be able to communicate... most likly not on every channel but there should be some that the 2 of you share.
