Has anybody hooked one these up at home for home use, any ideas on how to best install. I was wanting to test it before installing on my boat. thanks .. j
That model is meant for marine (boat) use. You can pre-test it anywhere as long as you are providing the proper power source. It's meant for 12vdc. If you have a marine battery, or a car battery handy, just power it up from that. You do not want to plug it in to household current, you would fry it in a matter of seconds. I would suggest hooking it up to the power 12v outlet in your car of truck to test it.
Testimonial: "yes it's 12 0r 24 volts, and things like not standing in front of it I know. what i would like to know if someone has used it on land, and how to get the best performance out of it. has any one been able to hook up a LCD instead of the old CRT ?"
lcd would be great, I'm interested too
LCD will work just fine as long as the output signal from the unit is VGA (which is most likely), I don't see why an LCD wouldn't work. Performance is most effected by the area around you; out on the water you have a flat clear plain, in city, the more buildings and other obstructions you have the lower the performance.
