Question about Just Wireless Bluetooth Headset - BT-38
I just got a new BT-38K and I charged the headset for 3 hours until the red light went off. When I connected the headset to the phone it was still plugged in and it connected successfully. when I unpl
When I unplug the headset it disconnects and wont turn back on even though i let it sit and charge for 3 hours till the solid red light turned off. the Blue light would turn on while it was plugged in. couple seconds after i unplugged it, it would turn off.
3 Suggested Answers
SOURCE:
  • 6771 Answers
SOURCE: BT-38k will NOT charge. its new, just bought it 4
Let the unit charge overnight to make sure that is the problem, if there is no change return the item for exchange.
Posted on May 21, 2011
  • 6771 Answers
SOURCE: I can connect my headset
The rechargeable battery will need to be replaced to get it running properly.
Posted on May 28, 2011
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
BT-38k will NOT charge. its new, just bought it 4 hours ago, and it wont charge up
May 21, 2011 | Just Wireless Bluetooth Headset Wireless...
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
May 05, 2011 | Genius BT-03A Bluetooth Headset
How do I get my Uniden BT-109 in discoverable mode ? I have a new cell, and am trying to pair it with the phone , and have no manual?
First, make sure the device is charged and turned off. Hold the power button down until the LED flashes red and blue. The phone will then be in pairing mode.
Mar 16, 2010 | Uniden BT-108 Bluetooth Headset
Bluetooth setup
You need to pair your phone with your bluetooth headset.
  1. Turn on your phone's bluetooth and search for bluetooth devices.
  2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Nov 11, 2009 | Radio Communications
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Jabra BT 5010
I have the same exact problem... I went to the shop and replaced it and again the new one doesn't charge. F***** jabra did anyone tried to call the jabra support about this ?
May 09, 2008 | Radio Communications
Just Wireless Bluetooth Headset - BT-38 Logo
93 people viewed this question
Top Just Wireless Radio Communications Experts
Marvin
Marvin
robert
Don Eagan
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
