The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
LG lds4821 overheats filter board and burns it. Probably another part shorts and causes excessive current. Replacing the filter board makes dishwasher run but problem persists
The leak is coming from the loose gasket in the fan assembly (blower) connected to the vent cover. What I did to fix my leak was a simple step of adding petroleum jelly (e.g., Vaseline) around the gasket holder and reuse the same gasket (clean all parts first, including the gunk inside the fan blower assembly) and the leak stopped!! My wife was so proud of me!
You have a bad membrane touch control. Check your owners manual for warranty on the electronic control. If it is out of warranty you need to call an authorized LG service dealer for a quality repair.
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
