Mitsubishi WS-65313 65" Rear Projection HDTV Logo
A
Anonymous Posted on Jun 07, 2014
How do i connect my dvi to vga to my misubishi ws-65313
Robert Johnson
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Jun 07, 2014
Robert Johnson
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
151992
Points
887
You can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Nov 29, 2007
SOURCE: Misubishi WS-65613 Flashing green reset light
You will not need SAMS on this one,Frank! I fixed four Mits. with
your symptom in the last two weeks.....parts = 1000mf/25v caps
105 degree hi-temp X 4.......Location = DM module...for pix's...
[email protected] copy..........
I have improved above procedure....When finished with repair of
PCB.,I place it secure in sockets , with two screws on end of
module back in place.THEN I slide cover down over module
and put the side screws in..........
Be gentle and if you need more help............T.
Anonymous
  • 6 Answers
  • Posted on Jan 13, 2008
SOURCE: Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Ekse
  • 13435 Answers
  • Posted on Mar 30, 2008
SOURCE: Mitsubishi Ws -65313 65in
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email support[email protected]
Robert Johnson
  • 395 Answers
  • Posted on Sep 03, 2008
SOURCE: ws-65313
this is correct! this tv does not have the ATSC tuner built in. 1080i is a format of the digital broadcast approved by the ATSC. you must have a source of this format to veiw this format. standard cable boxes and satilite boxes altho digital are not outputing HD formats so you need to have the HD boxes to veiw HD 1080i and the broadcasters must be broadcasting HD to get true HD.
Chris
  • 197 Answers
  • Posted on Nov 16, 2009
SOURCE: weight of T.V.
According to a quick Google search, it weighs 325lbs
How do I connect a bluray player to Mitsubishi WS-65313
Check the connections for firmness. If the converter works properly, there shouldn't be any problem other than this.
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.
also, don't buy any TV or electronics on CL as people dump their problems on someone else..
WHAT CABLE DO I NEED TO CONNECT HDMI TO MONITOR LINK DVI
I do not think the model listed here has either a HDMI or a DVI---if trying to connect a HD signal to the set it must be connected via the DTV input which is component but HD.
How do i connect my tv to cpu
This depends a bit on the computer. The only compatible input is the VGA port. (You need a 15-pin VGA monitor cable with ferrite core to avoid interference.) If your computer is a newer model with DVI output but no VGA port, you will also need a DVI to VGA adapter.
I hope this helps.
2answers
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
