Xerox WorkCentre Pro 428 Copier Logo
a
ashwani kumar Posted on Jun 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Meaning of u3-3 in 428
Mfd gets ready position. at the time of start copy. it shows code u3-3
Tammie Duggan
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 57 Answers
  • Posted on Jul 10, 2014
Tammie Duggan
Expert
Level 2:
New Friend:
Night Owl:
Answers
57
Questions
Helped
25710
Points
165
Http://www.omkarmin.com/pdf/workcentre-pro-423-428-printertec-23924.pdf
U3-3
(4133)
ROS failure
Abnormal power adjustment
value to the laser diode
when the diode is forced to
go on
POWER
OFF/ON
2answers
Pls show me how to reset Triumph-Adler DC2018 error code c6400
Thanks alot. It really worked for me, i mean the reseting procedure of menu>service sett>press #+start button+enter same time>enter 163>enter>go down to Execute>click start button. Then Restart machine. Wait a little so it adds toner then say 'ready to copy'. Hope somebody finds it helpful too
1helpful
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Code E000001-0004 what is this code and how to fix.
this is error for abnormal rise of temperature, if it is not seriuos ( I mean nothing faulty ) you can reset it in service mode.
Procedure:
While the copier in copy ready or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose:
COPIER
FUNCTION
CLEAR
ERR
Hope that helps!
16helpful
3answers
1helpful
Fan motor on condensor not starting. I have located the capacitor but unable to recognise any writing. it is a12000btu split unit.
There are two type capacitor. One for running capacitor for compressor and one for condenser fan motor by each separate capacitor. Some times two in one capacitor being used. Just check in your condenser unit, in your 2 in one capacitor, there are three parts and one has four pins and other two has each two pins where you can clip the wire.Remove existing wires and replace same with new capacitor.
Now, in this capacitor near each each part mention as "C" "H" " F". Cmeans compressor common and H means for compressor starting and F means fan starting. Be careful don't interchange any wire.
And also while replace capacitor don't add or reduce the mfd. Ex.. your existing capacitoris 35+3 mfd means 35mfd for compressor function and 3 mfd for fan motor function. Hope helpful.
Check engine light came on for about an hour then went back off..Tried to get it to come back on but couldn't ..Today the car would not start,engine just turned over let it sit for about 10 minutes and it...
To many things that can cause the issue your having. Drive to Auto Zone and they can scan your PT Cruiser free of charge and can give you the recommended solution to address any DTC codes that is retrieved.
Thank you for using fixya and post abck with your DTC codes.
3helpful
2answers
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
