Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu. Related Reading:How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings. How to Reset Samsung LED TV to Factory Defaults
To do a factory reset [system reset] you have to enter its service mode option. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Details about how to enter, adjust and exit service mode [factory mode] to many popular brand TVs are given.
Pull out the battery, and then reinstall it. Power on the phone and you should be able to access your information.
The following procedure will allow you to perform a factory reset, which would require access to the Standby Screen, and Menu. If you are just trying to access your phone, reset the battery.
To reset the handset to
the factory default settings, follow the steps below:
From the standby screen,
press Menu
Press Settings
Press Reset Settings
Press on any of the following to check their boxes:
All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
Sound Profiles:
Only
sound profile settings will be returned to default values
Display and Light: Only
display settings will be returned to default values
Phone: Only
phone settings will be returned to default values
Alarms:
Only alarm settings will be returned to default values
Press Reset
Enter the password default password is "0000", then press OK
If prompted, Enter the password
again to confirm then press OK
Press Yes to Reset the handset's settings to the factory defaults
Just set it to factory defaults first. Setting it to cactory defaults, will reset all the items except picture settigns. Parential password will also be get resetted. You have to set it later. To reset the TV to factory defaults, do the following.
[1] Push Menu button and select Setup.
[[2] Select Reset To Defaults from the drop down window.
[3] Push OK button.
The TV will reset to factory defaults and will display it. After that it will switch ON again. Ok
its a generic problem, open the dvd tray and keep it open, go to setup with remote and look for factory reset/default (might be inside preference settings) ok on factory reset..you might need password from your manual :)
