Question about HP PHOTOSMART PLUS B209A All-In-One Printer
How to I remove the print head for HP C7250 printer?
SOURCE:
  • 566 Answers
SOURCE: Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Posted on Jul 29, 2009
bob_computer
  • 3153 Answers
SOURCE: HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Posted on Aug 23, 2009
SOURCE: I have an HP Photosmart C7250. A few days ago,
I have the same problem
Posted on Dec 20, 2009
pineworks
  • 4345 Answers
SOURCE: HP C7250 ALL-IN-ONE
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 414 Answers
SOURCE: HP c7250 All in One
Ah the C7250, my favourite pain in the a***!
This machine really lets HP down, they are a fantastic company for print machines but this photosmart rubbish is a real headache.
There is such a thing as a defective cartridge, but you've already tried more than one set. And of course I am assuming your not using the refilled or reconditioned variety? Or have ever? That is a big no no.
You'll likely find that a service will get this back on its feet, but this is an extremely common issue with these printers and if its in warranty I'd get it back in the shop and quick, hopefully change it because you'll always have problems with this model.
Sorry for the bad news, I service HP printers and although on the whole HP make some fantastic printers, this isnt one of them!
Posted on Jan 08, 2011
No black colour on prints
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 21, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
Black Ink does not print...I've tried cleaning the jet, replacing the ink cartridge, cleaning the cartridge intake....but, still no ink is flowing for some reason...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 16, 2011 | HP Photosmart C7250 All-In-One Thermal...
I installed an Hp Color cartridge on my C7250 it is not recognizing it.
If it is not an original hp cartridge try original cartridge!
If it is an original hp cartridge you probably need a new print head.
Nov 23, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Can you refill the black ink cartridge on the c7250? If so, how.
Thermal printer? Normally a thermal printer doesn't have cartridges.
Anyway, my opinion is you should not refill ink cartridges. I have a basement full of printers with dead print heads due to third party ink being used or third party cartridges being used in a wide assortment of printers including a HP Photosmart.
Don't run the risk to save a couple bucks, please.
Thanks for you interest in FixYa.com
Jan 27, 2010 | HP Photosmart C7250 All-In-One Thermal...
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
201 people viewed this question
Clive
Clive
Thomas F. Schneider
