Canon PIXMA iP2000 InkJet Printer Logo
A
Anonymous Posted on Jun 07, 2014
How to reset ink on ip2770 - Canon PIXMA iP2000 InkJet Printer
1helpful
Error code on my canon mx330 5b00 how do I fix that - ink absorber sponges full?
What is 5b00 error? Canon Pixma iP2770/iP2772 error code 5B00 mean the waste ink counter reset (yellow and orange light, flashing alternately 7 times). ... When try to print, show up error message "The following ink may have run out", press and hold RESET button 7 seconds, then released them
1helpful
My.canon ip2770 does not print. It blinks alternately green and orange.
How to reset Canon Pixma iP2770/iP2772 error 5B00, follow instruction bellow;
1. Turn off printer
2. Press and hold RESET button
3. Press and hold POWER button.
4. Released RESET button, POWER still pressed
5. Press and released RESET button 5 times
6. Released POWER button
Now, printer on SERVICE MODE condition. In this condition, computer detect found new hardware.
7. When computer detect FOUND NEW HARDWARE, wait about 20 seconds and press CANCEL
8. Open software resetter Canon Pixma iP2770/iP2772 - download Re-setter Canon Pixma iP2770/iP2772
9. Set Destination - Region : select region - SET - OK
10. Load paper = 1 sheet
11. Clear Ink Counter - SET - OK
Wait, the printer will print D=000.0
12. Ink Absorber Counter - SET - OK
13. Reset iP2770/iP2772 is done, now turn off printer.
14. Turn on printer and try to print
Have problems when use software re-setter, read this Problems When Reset Canon Printer
15. When try to print, show up error message "The following ink may have run out",press and hold RESET button 7 seconds, then released them
How to reset printer ip2770
The waste ink counter is full, you need to reset it. First, download the resetter PCM_servicetool (.rar) Step 1: enter in service mode in order to used the resetter:
Alternate blink green and orange canon ip2770
Ink absorber is full or waste ink pad is full. You need to reset your printer but you have to follow the procedure on how to enter the service mode.
2answers
2answers
How to fix Canon pro9000 error E08 or iP2770 error 5B00
Your B500 is most likely a waste ink full message, so try this
http://ekohasans.blogspot.co.nz/2011/08/how-to-reset-canon-ip2770-error-5b00.html . You need to download a service tool and reset the waste ink levels, then dissable the machine to remove clean and replace the waste ink pads. You could get away with just doing the waste ink reset but beware ink overflowing from the base of the machine. The E08 error also seems to be a waste ink and may also need a service tool to reset.
I cannot print from canon ip2770 printer...the orange light flashes five times
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
6helpful
ERROR 5B00 IP2770
How to Reset printer canon ip2770 (E 5B00) ip2770.jpegIP2770 Resetter v1074 I have tried. IP2770 Resetter was sent by our friends in Jambi, and hopefully this iP2770 Resetter runs perfectly. Resetter is free passwords ... and FREE
How to Reset Canon IP2770 Error 5B00
Download Canon iP2770 Restter v1074 free pass Here
(Do not forget to turn off the download manager, for a successful download)
Go to the iP2770 Service Mode:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
V1074 iP2770 Resetter Then run it:
1. Prepare 2 blank paper in the printer
2. In the menu "Clear Ink Counter" click "Play" and "Platen"
3. Click Test Print ... Done ...
(In some experiments sometimes "platen" unable / err message appears, but no problem, still can work well)
Hopefully Successfully
112helpful
4answers
old marine
old marine
ZJ Limited
ZJ Limited
