SOURCE: needle keeps hitting the pressure foot and breaking
your machine probably needs to be retimed.
SOURCE: BabyLock Audrey won't zigzag
You do need to take it back.
To save on driving, call and ask for an appointment so you do not have to leave the machine and make a second trip.
SOURCE: Imagine BabyLock Serger. The hand wheel only moves
I suggest having a professional look at it, if you don't have one near by. You can try to fix it yourself, but if release the gears the machine willl most likely get out of time and not sew properly.
How to release gears on each gear are 2 set screw, usually a hex head. just turn it counter clockwise and it will release.
But remember the machine will have to be timed, which is a bit to difficult to explain over text chat.
Testimonial: "Thanks for the suggestion. I took it in for service today because I don't want to ruin the machine. This is the second time the gears have locked up, "
SOURCE: The foot pedal that controls my Babylock Proline
try these two websites for the part
sewingpartsonline.com
sewvacdoctor.com
SOURCE: I have a babylock 1556
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
