Precor EFX 546i Elliptical Version 4 Logo
A
Anonymous Posted on Jun 06, 2014
My Nordic track elliptical is making a clunking sound coming from the handles bars. What can I do?
Treadmill Repairs Brisbane
Level 2:
New Friend:
  • Expert 338 Answers
  • Posted on Sep 25, 2014
Expert
Level 2:
New Friend:
Answers
338
Questions
0
Helped
77746
Points
473
Hi There ,
Take off the covers and check the bolts .They do come loose.
2answers
My Nordic track elliptical audio strider 800 console does not work. I have changed batteries and I have purchased the adapter and still does not work. What can I do?
Better to buy a new console. It would be difficult to repair the existing console.
I'd you wish to get some details about elliptical repair then check the below added link.
http://electro-medical.blogspot.com/
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Extreme noise in elliptical when using
With regard to the clunking in the NordicTrack E7sv it turned out to be the left side wheel to crankshaft connection. It had come loose. I removed the left side foot rods and wheel cover plate for access. I re-seated the wheel on the shaft and tightened the hardware. Noise gone. So is all the squeaking associated with it loosening.
Elliptical noise
These motors has plastic gears...gears may be or is getting bad.
1helpful
Nordic track elliptical clunk
I had a clunking everytime I would use my Nordictrac 1300, the clunking was on the right side. I opened everything up searched everywhere was about to scrap it, when I found the wheel that attaches to the stride handle was cracked. it is the wheel that rolls along the ramp while you are striding, looks like a roller blade wheel. I downloaded the manual. looked up the part and found them at Amazon for $60 per wheel, very expensive! after looking at everything, it looked like the wheels that raised the ramp up and down were the same. So using an allen set, I pulled the wheel that raises the ramp up and down and replaced the cracked wheel with it. I then took the cracked wheel and placed it on the piece that raises the ramp up and down, since it doesn't get as much activity as the stride wheel. if you have to do this know you will need a pair of pliers that takes those C ring clamps off, because the wheels are secured with those rings. took a damp rag, cleaned out a little dirt from the rails, tested it out, runs smoothly at low and high intensity, no more clunking!
1helpful
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
