Honda 25cc 4-cycle Mini Tiller Logo
A
Anonymous Posted on Jun 06, 2014
HOW TO BREAK DOWN THE GEAR BOX TO GET TO BEARINGS
TINES QUIT TURNING, NEED TO GET TO THE BEARING TO FIX. HOW DO YOU BREAK DOWN THE TILLER TO GET TO IT. HONDA 25CC 4 CYCLE MINI TILLER.
2 Related Answers
Anonymous
  • Posted on Jun 01, 2009
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Anonymous
  • Posted on Jun 15, 2009
SOURCE: Where can I find parts for Honda mini-tiller FG100?
1- http://www.alamia.us/category_s/777.htm?gclid=CMKhnqnT9JoCFQoMDQod7U3Ndw
2- http://www.planopower.com/store/honda/fg100.shtml
Tiller tines don't turn when I throttle?
Here are some possible causes and solutions:
Belt Issues: If the drive belt is broken or loose, the tines won't turn. Check the belt tension and replace the belt if necessary .
Idler Assembly: If the idler assembly is not properly tensioning the drive belt, the tines won't turn. Adjust the idler assembly or replace it if necessary .
Engagement Cable: If the engagement cable is loose or not tensioned properly, it may need to be tightened or replaced altogether .
Transmission Issues: If there is an issue with the transmission, such as a broken gear, the tines won't turn. Stop using the machine immediately and inspect the transmission .
Since you mentioned that your tiller tines were turning fast after replacing the carburetor and then stopped turning after connecting the throttle cable, it's possible that there is an issue with the engagement cable. You may want to check if it's properly tensioned and connected to ensure that it's not causing any issues How To Fix Tines That Will Not Move - Tiller Repair
Oct 30, 2023 • Garden
2answers
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Tiller runs great just having a problem with the tines turning plowed my garden last week and for some reason the tines quit turning like its locked or something please help me
Two possibilities. Something has jammed the tines.
Pull the spark plug wire off and tuck it away someplace so as not to touch the plug.
Tip the tiller up and examine the tines for obstacle such as a rock. If there is nothing jammed try to turn the tines by hand. If the they turn freely you most likely broke a shear pin that secures the tines to the axle.Clean the axle and tines and examine very closely for the pin.
If sheared ( broken) you will need to drive the broken piece out and replace the pin.
There may also be a problem in the transmission case. You would need to remove the tines and case to open it
Apr 01, 2016 • Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 • Garden
4helpful
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
2answers
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
1helpful
2answers
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
