Question about Faberware 12-55 Cup Coffee Urn
How do I replace broken Ceramic Tube?
It still works. Can I buy just the ceramic, or just the whole pump tube?
2 Suggested Answers
SOURCE:
  • 176 Answers
SOURCE: Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Posted on Aug 11, 2010
Anti/calc iron water pours out from evry where
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl222/H 2200W Steam Spray Iron...
How can i replace broken sparkplug 1998 windstar rearside
Hi Isaac, I guess your problem is that the plug has broken off inside the plug tube and you need to remove it. If it broke off while you were replacing it, (fitting a new one) has it cross threaded and damaged the cylinder head? If so you'll need to force on the plug wrench past the damaged electrode and loosen it the normal way. If the threads have been damaged, you may need to remove the head. I know there is a Locktite product which is used to repair damaged threads, but as we have never seen it here and I don't know how well it works? If the plug ceramic part broke off during fitting you'll need to do the same. Force the wrench down onto the faces of the plug and removal. Taking it out from the tube will need some fiddling around with a long nosed pliers or a rubber tube. Once loose push the tube onto the end (which will be difficult if its bent. Just take your time. Regards John
Jul 02, 2012 | 1998 Ford Windstar
Broken ceramic tube that contains the heater coil in my toaster
take it in to an appliance repairs shop and have it fixed proeprly
Mar 07, 2017 | Cuisinart CPT-50 Heat Surround Toaster
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
Is there a fuse or circut breaker in the spacemaker?
yes a ceramic 15 or 20 amp fuse replace only with ceramic fuse sold at most hardware stores,its under outer cover its a 1" long by 1/8" dia white glass tube
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken ceramic top
hi...no nid to replace the ceramic top,coz it is very expensive compare to buy a new one.the price of the glass ceramic top is mostly half or 3/4 of the actual price of the new one.much beter to buy an new one,get an new & the warranty but the glass is not covered in waranty for all brand.
Sep 10, 2009 | Cooktops
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Broken ceramic
Need a Rival ceramic liner (4 qt) replacement. Where can I find one??
Nov 10, 2007 | Rival 3040-VG 4-Quart
Faberware 12-55 Cup Coffee Urn Logo
63 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Bob Janelli
Level 1 Expert
ellenskitche
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
