SOURCE: RE Kirby uuser manual
Here is a link to instructions for changing the belt. Manuals are also available.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
SOURCE: I need to remove the outer bag from my Kirby
In order to remove the outer jacket from your Kirby do the following.
Detach the top bag clip from the handle support. There is a plastic piece, just below the outer jacket, called the mini emptor. Turn it to the right to remove the entire bag assembly. Removing the outer jacket is dificult and even harder to put back on so this is what I would do.
Unzip the outer jacket as you were going to change the bag. Remove the paper bag. You will then see a long black tube, that has a 90 degree elbow at the top. That elbow is attached to the inside of the bag with a snap type strap. Remove the strap, then you will be able to move the tube, while you clean out the inside of the bag. When finished put everything back where it was.
Testimonial: "Thank you, thank you, thank you - it worked. I did read the manual before posting the ? and didn't find a solution I felt comfortable with. Susan"
Here is a link to my guide for cleaning the Kirby cloth bag...
It should be helpful. :0)
Marci
