SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem.
worse case scenario is the transmission is bad, but this is unlikely.
SOURCE: Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
SOURCE: kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
