I need to delete duplicated photos from ipod nano 7th gen. Photos don't appear when I open itunes, music only. Easy answer please
Select your iPod nano in iTunes and click Photos. "Select Sync Photos From". for verification. Click Delete Photo in the dialog that appears, then click Apply.
To remove duplicates songs from iPhone/iPad/iPod, you get 2 methods. The first one is to make use of iTunes, while the 2nd one is making use of 3rd-party duplicate remover tool. Below guide explains how to delete song duplicates from iPhone/iPad/iPod with a powerful 3rd-party program easily. There recommend Leawo Tunes Cleaner. Leawo Tunes Cleaner is a Windows-based professional iTunes cleanup program that could help you fix your iTunes music library and other music folders by adding song tags and removing duplicate songs. It could act as iPhone duplicate remover, iPad duplicate remover, iPod duplicate remover and iTunes duplicate remover to help you easily find and delete duplicate songs for iPad, iPhone, iPod and iTunes in clicks. First, download Leawo Tunes Cleaner ' Leawo Tunes Cleaner for Mac and install it.
Step 1: Launch Leawo Tunes Cleaner
Download, install and open Leawo Tunes Cleaner. Choose the "Clean-up Duplicates" option on the main interface.
Step 2: Set scanning mode
Select a duplicate scanning mode to detect duplicate songs in your iTunes from Quick Scan and Deep Scan. Quick Scan mode is based on song tags including name, artist, album, file size and time, while the Deep Scan mode adopts Acoustic Fingerprint tech for deeper scanning. Choose the desired one.
Step 3...
For more information: 2 Best Ways to Delete Duplicate Songs on iPhone/iPad/iPod
You'd better cleanup your iTunes library firstly. Just click "View > Show Duplicate Items" and then you would just check off the duplicates that you wanted to remove. After removed all the duplicates in your iTunes, sync it to your iPod, then all duplicates in your iPod will be removed automatically.
Source: http://how-to-delete-duplicates-in-itunes.newgenresoft.com/ How to Delete Duplicates in iTunes 12 11 10 9 automatically
SOURCE: DELETE ALL DATA ON IPOD NANO MODEL MA477X
When you sync it to your itunes it will remove all of the media which was previously synced.
SOURCE: IPOD NANO 8GB
open itunes, connect ur ipod and click the photos tab then remove the photos you want to delete.
SOURCE: how to delete photos on IPOD nano?
If your iPod can manually sync I'd choose this option then you will know you are in complete control with what you want on your iPod including photos.
Another consideration is to buy a charger plug adaptor. Sometimes when I want to change back to automatic sync option on the iPod, I'll use the charger plug which is a plug and uses the same USB link cable supplied with the iPod. That way I know that Im able to charge the iPod without anything getting on.
SOURCE: what version of itunes is compatible with iPod nano 5th gen?
I have the same iPod and it works with any version, at least mine does. Try downloading it here itunes.com
that's where I went to get mine. And it worked. Hope this helped!
