Shuit off water and remove the three bolts under the bowl in back lift off tank and remove gasket by pulling it off the bolts install new bolts inside tank install the white washers on the bolts then install them in tank and putr gasket on bottom of the tank and reinstall the tank to bowl and tighten down nuts be carefull not to over tighten bolts cause the bolts will snap the porecelain ears on the toilet.
