More than likely it's going to be one of these two things. Number 1 the battery is going out. Number 2. check the charging port to make sure that the their separation between the connectors. If there's any damage on the charging port or the plug, you could be cross wires and causing it to overheat. If the charge port and the plug look fine, check Amazon.com for battery a replacement. you will have to change that yourself but you find a real cheap price saving from 5x to ten times the cost of the battery as to have some else replace it for you.
