Computer set to boot from DVD when present but boots from HD instead
SOURCE: boot from cd/dvd
goto BIOS by pressing F2 or Del while booting then in the boot priority menu change first boot device as cd rom...
SOURCE: Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
SOURCE: regarding a IBM ThinkCentre 8183: I want to instal a new H Drive
Make sure the disc you are using is an install disc and not an upgrade disc. It sounds corny but I had the same problem when I wiped my hard drive and tried to reinstall.
SOURCE: Computer will NOT boot from a DVD but will from a CD
Maybe the lens is not compatible with DVD it may be CD reader and not DVD
SOURCE: HP a1250Ncomputer wont boot up.
OK, ONE DVD MUST be set as MASTER and ONE as SLAVE. The master MUST be on the "End" of the cable, the SLAVE, on the other. First try with ONE drive, and if you get it working, swap them out too at first, then after establishing that it works OK with just One, the MASTER, then introduce the SLAVE. Do Not forget to RE-JUMPER between swap outs.
